Preamp volume Log Out | Topics | Search
Music Man Amps Discussion Forum » Adjustments, Maintenance & Calibration » Preamp volume « Previous Next »
J.A.
Posted on Wednesday, October 29, 2003 - 10:39 am:
In order to make my MM HD410 sound really clean when using the bridge pickup on my Telecaster and using a wah-wah, I have to keep the preamp volume pot on not much higher than 1. In "normal" conditions when using a softer sound from my guitar it stays clean up until 4-5. Is this normal, or should there be more headroom?
langley
Posted on Thursday, October 30, 2003 - 09:45 am:
A troubleshooting Method.
Remove the wah-pedal. Use your settings, and
Master vol on 10. Reverb / trem off and zeroed.
Still getting distortion at Gain > 1?
No: R/R pedal.
Try switching cables.
No: R/R cables.
Try switching guitars.
No: It's a guitar problem.
Set tone: Treble(6), Mid(4), Bass(3).
No: Use the above tone settings.
Re-do last test using other channel,
then re-do again using input # 2.
Distortion audible at all speakers?
No: Isolate suspect speakers.
If still getting distortion at Gain > 1,
it's time to see your neighborhood amp tech.
Hope this helps.
